1950 MT
J.BENNETT
04-04-2006 11:27:42
hey gentlemen: having a weird noise comming from the underside of my tractor just below the seat ? it only happens in first and reverse. it sounds like a loud clicking almost and is constant when in the gears listed above. any ideas? i have not had the pleasure of splitting a tractor before, and didn't want to if i could keep from it. took off the top of the tranny plate and couldn't find any chips. what else could it be ? please toss a few suggestions my way. i have it most of the way tore down for a top end rebuild and a paint job, so it is now or never. thanks
J.BENNETT
04-04-2006 14:26:07
 Re: 1950 MT in reply to J.BENNETT, 04-04-2006 11:27:42
hey thanks, i'll give it a try. anything beats dropping another $ 700 and no guarantee.
tstex
04-04-2006 14:03:15
J Bennett,
I too had the same type of clicking [not real loud] while i had my 51 MT in 2nd gear.
So, i did a search for you and found the post. I especially like Wayne-in-Tn response. He has helped me on all Dubuque issues everytime. Hope this helps and here it is:
Gentlemen,
My 51 MT just started making a different sound from the transmission area while in second gear only...all of the other gears sound the same.
I have not tested it under load since the sound has just changed in the last 2 times I fired her up...yesterday and today. I have not done anything to this area to cause the change...
Wanted to know if there is anything in particular to try, test, change or examine? Please let me know if you have any questions.
I recall reading some threads awhile back that some gears give us a harder time than others...is this typical to dubuque's or am i just blessed?
Thanks again as always for your assistance.
regards,
tom
[Reply] Clooney 11-17-2003 03:36:12
198.208.6.35
4356
Re: 2nd gear vs 1st, 3rd 4th in reply to tom, 11-16-2003 16:42:47 Tom, when you drive it try it both with & without the PTO engaged to see if that is effecting the noise. ~Also make sure that someone hasn't engaged the belt pulley lever?
~Those are 2 places that come to mind on a trans noise change condition..
[email protected]
Henry J 11-16-2003 18:39:36
205.188.209.70
4332
Re: 2nd gear vs 1st, 3rd 4th in reply to tom, 11-16-2003 16:42:47 tom
What kinda sound are you dealing with? Each gear in my tranny makes a different sound, but they remain constant. [Reply] tom 11-16-2003 20:13:07
209.63.67.242
4343
Re: Re: 2nd gear vs 1st, 3rd 4th in reply to Henry J, 11-16-2003 18:39:36 Henry,
That is a very fair question...I am going to drive the MT some more and see if I can come-up with a better/more definitive description...but you are right, the sound just changed and now I need to try to explain the difference...thanks for the follow-up. Will post back in a couple of days...
tom
Wayne in Tn. 11-17-2003 07:57:57
64.7.225.237
4374
Re: Re: Re: 2nd gear vs 1st, 3rd 4th in reply to tom, 11-16-2003 20:13:07 Tom, about every Dubuque I have owned, had some type of transmission noise. Very rarely, it can be a bearing, but usually its just 50 plus years of wear on those 'straight cut' gears. 140w gear oil will help some. Usually which ever gear was used the most, will make the most noise, maybe second. Also I have seen every gear make its own distinct sound, even reverse. It is hard to tell the difference from a bad bearing and just normal gear noise. Once, I tore one down, determined to stop any gear noise. I put over $700 worth of bearings in the trans. and final drives. Then the first time I drove it, the noise was exactly the same as before, sooo..... ..?
