To Mike in Shendoah Valley -- (1) You need to have a service manual of some type if you have any hope of putting that tractor back together so that it is useful at the end. (2) I wouldn't be concerned about where the clutch drive disk is at this stage. Besides -- it is the flywheel postion that is paramount here, not the clutch drive disk!???? (3) Now -- Where were we? Oh yes, the correct method of valve timing for the "A" is to place the engine in a certain position and then install the flywheel in another "certain position". Read on. (a) You must have the tappet cover off, and the tappets for the left cyclinder must be reasonably close to 0.020" gap. Using the flywheel randomly installed or a strap wrench, rotate the crankshaft in its normal run direction until the exhaust valve of the left cylinder is JUST BEGINNING OPEN (0.000 TAPPET GAP). STOP! (b) At this time, the flywheel mark "L.H. EXHAUST OPEN" should be in register or with one inch of register of the index (reference) mark on the gear cover. (This would be at 3:00 o'clock if you looked straight into the flywheel). (c) If flywheel isn't within this range, remove it and reinstall it so that it is. (d) If you would like further help, call me (830) 627-0430 or write me . More later
