JD 60 runs wide open
Chrislucky
04-04-2006 08:12:02
I have a JD 60 2 cylinder that runs wide open. I have not done any work on the tractor. The tractor was running fine. The tractor sat for a month or two and when I started it agian it would run almost wide open.When I move the throttle lever it doesn't seem to make a difference. I was told to check the govenor weights which I have done they seem to be fine. Where is the most likely problem.
Dave NE IA
04-04-2006 10:24:03
 Re: JD 60 runs wide open in reply to Chrislucky, 04-04-2006 08:12:02
Grab the throttle linkage at the carb and see if perhaps the throttle shaft is stuck a little. I have seen this happen before. Dave NE IA
Blksmok
04-04-2006 09:00:53
Chris..... check to see if your throttle plate is still attached to it's shaft inside the carb.
