We (dad and I) have an early 2010 gas (#12197 if I remember right). Have had a bunch of PTO engagement issues since we got it (but it never slipped if we got it running). The previous owner had it apart....and did something wrong!Anyway it is now apart in the barn. Have tried putting it back together a few times, and keep hitting snags. The sliding collar and clutch shaft engagement seems to be one of the major culprits. The clutch shaft is slightly wore from grinding, but we're pretty sure it's good to use. However it does have a little bit of up and down play. Maybe a good 1/16 of an inch. I believe this is not good, and probably causing binding/non engagement...or is this normal? The sliding collar appears to be in good shape, but ALSO seems to be the wrong one. The book dscribes the early one with a rounded edge, and a late one with a thicker side. The collar on the tractor matches the description of the later one. Has anyone mixed and matched like this? I would think it would still work?!?! Ae have a copy of the JD228 clutch adjusting tool. Is it a good idea to use this on a used clutch, or will it only work for a new clutch? Just by checking, ours is WAY off. But it never slipped, I don't want to start adjusting and get it even worse. Thanks for any help, we're scratching our heads on this one! Brandon My Industrial John Deere website John Deere Diesels The LaGrange Engine Club
