Help with a JD 60
Brad in VA
04-03-2006 17:27:48
Hello, i have found a JD 60 that belonged to a friend of my dads. We know about most of its life, where its been and whos owned it, anyways we have the chance to buy it. It was parked under a barn in good condition due to a burnt valve. The motor had recently been gone through. Then the farmers 3010's front end went bad so he used the front out from under the 60 to replace it. Then the barn went bad and fell on the 60. So the sheet metal is kinda rough now and it is missing the front end and the valve is burnt. Thats the bad. the good is we know the history, it means something to me to know the history of the tractor. and it has a complete 3pt. hitch. He wants 500 for it as is. Everyone think this is fair? he is selling it as a parts tractor. I want to fix it up. Any opinions would be helpful. Thanks Brad
Bobl1958
04-04-2006 08:39:24
 Re: Help with a JD 60 in reply to Brad in VA, 04-03-2006 17:27:48
CLW is absolutely right with his answer. Jump on it if it is as you describe. Bob
CLW
04-03-2006 17:59:54
Brad, for $500 it is a good buy. A double front or single front can be had for $50-150. Valve job won't be much. Sheet metal can be fixed, replaced or used like it is. If you are looking for a good two cylinder the 60 is hard to beat. CLW
Brad in VA
04-04-2006 16:14:36
 Re: Help with a JD 60 in reply to CLW, 04-03-2006 17:59:54
OK went back and talked to him and the three point does not go with it and i checked more closely on more items.... I found that the intake manifold is cracked, all the levers are froze, as well as the clutch. The tractor needed pto clutches before the valve got burnt. The rims on the back are shot as are the tires, the seat box is shot. the nose cone is shot.... ect.. I told him thanks but no thanks. If i can find a tractor that needs a tranny and rear I think ive found a donor. Thanks for the replys, just wanted to give an update.
CLW
04-04-2006 16:27:43
 Re: Help with a JD 60 in reply to Brad in VA, 04-04-2006 16:14:36
You made a wise choice. You can find a nice running 60 for around $2500.
CLW
