A Too much camshaft play???
Jason(Pa.)
04-03-2006 16:29:30
Im trying to figure out why my A has gottin worse when running for the last couple years. I asked some questions while back and someone said about checking the cam bearings. The other day I took the Governor plate off and tryed prying up on the cam gear. There was alot of movment. Is this normal? I assume that the cam bearings are of the roller bearing type. Thats what it looks like in the IT manual.
Mike M
04-03-2006 18:23:40
 Re: A Too much camshaft play??? in reply to Jason(Pa.), 04-03-2006 16:29:30
May as well go ahead and pull the end cap off the LH cam bearing and you will see for sure what shape the bearing is in. I have gotten by a few times by just replacing the LH bearing only as this one seems to wear the most and is the easiest to replace. Also if you loosen up the push rods and remove the tension from the cam it will be alot easier to tell how much play you have.
Jason(Pa.)
04-03-2006 18:30:31
 Re: A Too much camshaft play??? in reply to Mike M, 04-03-2006 18:23:40
Ok,thanks for the help. I'll dig into it soon.
RedJD
04-03-2006 16:54:25
Yes, they are roller bearings,there is a spring on the pulley side of the cam that controls the end play.Unless the spring is broke your bearings are probally worn,causing the play.
