Couple of misc '69 4020 questions
Nylon
04-03-2006 14:30:03
Wondering how to remove front dash to paint. Do the black ends on the hydraulic dash controls slip off or do I have to disconnect the levers from the control valves? How tough is is to pull the steering wheel off its splines? Is that a puller situation or can I pry it off? Then comes the throttle lever..any tricks to that?
Once I get to paint the dash, I have seen it painted every possible way. Right now mine has black base paint with green over the top that has failed. The instument cluster backing is black. I think that the instrument cluster is supposed to be black and then the rest is green. Let me know on this. I replaced the dash light bulb to find that it doesn't work. I have 1 2 position switch that light up the rear cab top and lower rear lights and one single positon pull switch that lights up all 4 front upper and lower cab lights. Wondering how the original 4020 switches were set up. I see the latter 4020s had a dial type switch. Was the dash light tied to the headlights or was it on an independant switch?
And finally. My seat adjustment was tough to get to work. I am 6-5 and wanted to slide the seat back. I was monkeying around with it 5 months ago and whoosh it went all the way back. That is fine and worked over the winter with the extra cloths but all the way back it is still a bit far back even for me. The trouble is that I can't get the thing to budge and come forward. Any tips on this would be appreciated.
Thanks,
John
Shane S
04-04-2006 12:13:58
 Re: Couple of misc '69 4020 questions in reply to Nylon, 04-03-2006 14:30:03
Nylon,
I don't know a lot about the 4020's, but you do not have to remove the steering wheel on my 4520 to remove the front dash cover (or the guage cover). It just has a rubber boot that covers the steering column, the front dash panel has a slot and can be slid over the steering column.
I apologize if this wasn't the question. Maybe you are replacing the steering wheel also???
Good luck,
Shane
Tx Jim
04-04-2006 03:36:38
John,'69 4020's don't have SCV"s handles in dash as they are in SIDE Console but the knob on pto lever will come off. You'll need a puller to remove steering wheel. On seat there is a flat piece about 4 in. long that you pull up on to move seat back,another lever that moves side to side to adjust height.HTH Tx Jim
Nylon
04-04-2006 12:06:41
 Re: Couple of misc '69 4020 questions in reply to Tx Jim, 04-04-2006 03:36:38
Sorry bout that TXJIM. I have a 68 not a 69. The dash levers for hydros have the black knobs and wonder if they slip off. Thxs for info on puller for steering wheel. Did all 4020s have the same size and number of splines? Want to make sure I don't get a wrong wheel if I get a new one.
I know how the seat is supposed to work. I cant get the bugger to slide forward. It slide back with some gusto once I got it to move but now I cant get it to come forward at all. I also cant make any height adjustments.
John
Tx Jim
04-05-2006 03:55:35
 Re: Couple of misc '69 4020 questions in reply to Nylon, 04-04-2006 12:06:41
John,the knobs for scv's and rockshaft will pull of of a '68 4020. On the seat there is a small cable that pulls seat rearward. The cable can hang or someone may have spring tension on it to tight. HTH,Tx Jim
