JCarroll wobble update JD 40
donwisc
04-02-2006 19:57:52
JCaroll, followed your sugestion, got the front end off. got a jack on the bolt but nothing moving yet however after moving the shaft up as far as it would go it exposed the tapered stud that engages the steering worm.
It is pretty beat up and worn on the bottom and I think this is the problem causing the front end wobble. That stud apparently is retained by a snap ring but I cant determine how to get it out without getting in with a dremel and grinding it out. Have you had any experience in this area?
Wayne in Tn.
04-03-2006 11:50:22
 Re: JCarroll wobble update JD 40 in reply to donwisc, 04-02-2006 19:57:52
If those studs are no longer available, you can grind off the braded side and turn them a few degrees and weld them back. This will give a new surface to run in the worm gear.
Mike M
04-03-2006 05:41:19
The tapered stud on the top that goes into the worn is a press fit riveted in place. I would have a new one in my hand before I remove the old one. You can grind the top riveted part down then you should be able to drive it out with a punch with proper support.
Donwisc
04-03-2006 07:04:18
 Re: JCarroll wobble update JD 40 in reply to Mike M, 04-03-2006 05:41:19
Thanks Mike I mistook the shoulder for a snap ring, sure is great to talk to someone who has been there before. Don
Mike M
04-03-2006 08:10:16
 Re: JCarroll wobble update JD 40 in reply to Donwisc, 04-03-2006 07:04:18
Glad to help.
"been there before" sometimes just forget the journey ! LOL
