38A FBJ 2B Magneto cap needed
Dave NE IA
04-02-2006 18:30:15
I have a friend who is looking for a cap on a fmj 2B magneto, (38 JD A) any sorces of new or used? He could switch over to a Wico, but probably would like to keep it as it as it came from the factory. Yes it should be correct if my research is correct. Thanks Dave NE IA
Dave NE IA
04-04-2006 10:36:46
 Re: 38A FBJ 2B Magneto cap needed in reply to Dave NE IA, 04-02-2006 18:30:15
Thanks guys, looks like we are perhaps beating a dead horse. Dave NE IA
Glen in TX
04-04-2006 16:34:14
 Re: 38A FBJ 2B Magneto cap needed in reply to Dave NE IA, 04-04-2006 10:36:46
Don't throw the FM mag away as it's worth something as parts but when the cap is bad and impulse and coil it can cost more to fix than a new Wico. That's why they are still making new Wicos.
Glen in TX
04-03-2006 08:00:11
Dave, The FM-J2B6 and other FM-J & FM-X2B6 mags weren't factory on JDs but sold by dealers back then as replacement mags. Good mags but some parts are too high for them like the cap. The BX2430 is the cap you are looking for and I am out of NOS & used ones and only special order those in now also and they are over $100 now with freight and that's if price didn't go up again. Like Duane said the gasket, brushes, screws and brass rod to coil are also extra and not included with the cap. Try looking for a NOS or used one or other mag I suppose or use some 5 min. epoxy on your old cap. I do have a few NOS dist. disks for that FM mag but they are sold on exchange basis only. All the FM caps and parts got pricy before buyout with price increases and most old stock is gone so new parts made are just higher now for them. Too many yuppies with Harleys will pay that price for the cap so they still make them new. If you find a good price on a LX2430 or WZ2430 cap and also a R2765 or FY2765 dist. rotor you can drill or grind the shaft on end to change for rotor and run that also but it won't look like the cap you have now with terminals coming out straight or upwards instead.
Duane Larson
04-02-2006 19:48:32
Dave,
The '38 A came with a Fairbanks Morse DRV2B magneto. An FMJ2B(6) was a replacement magneto for an A. Deere would have provided a Wico C as a replacement until the XH came out - they never used the J series.
That being said, caps are available but they are pricey. You might check with Glen in TX, or Robert's Carb Repair - they may have some. I don't carry any - just order as needed. As I recall, you also have to order the brushes for the cap, and the HV coil-cap rod unless you can transfer them from the old cap.
