520 water pump
Jason Z in MO
04-02-2006 18:24:27
The bearing in my 520 water pump went out. Took it off today and pressed it apart. I have the new bearing and seal.
The question I have is where the seal rides on the impeller hub face. The old seal wore a small groove into the impeller. Will the new seal, seal? Can the impeller be turned around?
I'm curious how this seal design works all?!?!?
Mike M
04-02-2006 18:35:29
 Re: 520 water pump in reply to Jason Z in MO, 04-02-2006 18:24:27
A very good chance it will leak if you run that old impeller. Buy a new one (expensive) or reface the old one. You can't really turn them around because of the fins on one side are rounded on the edges. I did have trouble one time with a reused impeller not press fitting back on the shaft tight enough and it loosened up and drifted back causing the pump to leak again. So I had to pull it off again and put in a new one. If I was working on a tractor for someone else I'd put in a new one so as not to have problems. I'd take a chance on a resurfaced one in my tractor because any problems it's my fault and I have to fix it.Only inconvience is to me not anyone else.
Jason Z in MO
04-02-2006 19:07:15
 Re: 520 water pump in reply to Mike M, 04-02-2006 18:35:29
Mike,
What do you think about brazing up the void and filing down? Probably would have to polish it up to get it smooth enough.
JD impeller is $90-100. A&I has an after market pump for that price...
Mike M
04-02-2006 19:41:35
 Re: 520 water pump in reply to Jason Z in MO, 04-02-2006 19:07:15
I just chuck them up in a lathe and take off some until it cleans up. It's usually not too much. I also polish them on something flat with some fine abrasive paper. As long as it's smooth and flat it should work. I just wonder about the seal wearing against the brass ? May be better ? may be worse ?
Jason Z in MO
04-03-2006 12:55:38
 Re: 520 water pump in reply to Mike M, 04-02-2006 19:41:35
Mike,
I don't have a lathe, some day I hope...
I think I will try brazing it then file/sand it back down smooth.
Thanks for your help!
Jason
Mike M
04-03-2006 13:02:40
 Re: 520 water pump in reply to Jason Z in MO, 04-03-2006 12:55:38
Know anyone with one of those large woodworking belt sanders ? That may work.
