6.5 GM diesel
bm3501466
04-02-2006 17:39:13
I have been having starting problems with my truck that has the 6.5 diesel. When I start the truck it often dies. When it does start successfully it will run with no problems. The truck will start perfectly between 3 or more hours after it has been running at operating temperature and then being shut off. Any time though between an hour to three hours after the truck has been off after running, it will either not start or it will die within a couple of seconds after being started. I have put a new lift pump in it, however it is still being contrary. What could be the problem with my truck?
I know this isn't a GM forum, but I know you guys know your stuff fairly well.
Dirtjockey
04-03-2006 10:37:56
 Re: 6.5 GM diesel in reply to bm3501466, 04-02-2006 17:39:13
I had a similar problem on my truck here in Kansas. The PDM will start to over heat in mid summer. I installed a relocation kit on mine from Link The kit includes a new PDM, resister and heat sync for the 6.5L engine. It really helped mine in hot weather. Removed it from the pump area where it tends to overheat and die prematurely.
gwh
04-03-2006 09:17:37
Make sure when changing a PMD that you transfer the "calibration resistor" in the PMD under where the flat electrical connector plugs in.
Blksmok
04-03-2006 05:06:53
BM.....6.5 diesel's are notorious for bad Pump Module Drivers (PMD) the black square, thin electronic control box mounted to the side of the injection pump. Also, make sure you have a good ground on your batteries and clean electrical connections between the fuse block and injection pump electrical connectors.
JRB
04-03-2006 06:36:29
 Re: 6.5 GM diesel in reply to Blksmok, 04-03-2006 05:06:53
I agree with Blksmok. I have a '96 with the 6.5 . It EATS PMD's. Replace yours and I'll bet your problem's gone. Good luck!
Bob
04-03-2006 07:33:07
 Re: 6.5 GM diesel in reply to JRB, 04-03-2006 06:36:29
Guys,
While the problem likely IS the PMD, the first thing to do is check the electric lift pump.
With the OEM setup, the PMD is mounted to the side of the injection pump, and cooled by excess fuel flowing through the IP, and returning to the tank.
Also, the system is more prone to getting air in it with the lift pump working, making for some "start and die" situations.
When the lift pump or the pressure switch that operate it fail, less excess fuel flows through the IP, the IP runs hotter, and the PMD will "heat soak" more at a warm shutdown.
The lift pump pressure SHOULD be checked, however, a "quick and dirty" check to see if the lift pump is running is to open the fuel filter bleed valve, typically remote mounted near the alternator.
If the engine dies when the bleed valve is opened, the lift pump is not working. I fuel pumps out the bleed hose, and the engine keeps running, the lift pump is at least WORKING.
Blksmok
04-03-2006 08:23:01
 Re: 6.5 GM diesel in reply to Bob, 04-03-2006 07:33:07
On cold starts, when you turn the key on and the glow plugs are activated, you should be able to hear the lift pump running as it builds pressure. It's located along side the truck's frame, right under the driver's seat. If that's not working you will have the problems Bob has described. Check that out first as it's a cheaper and quicker fix than replacing the PMD if your's is still mounted to the side of the pump. Many PMD's have been mounted to an external cooler (finned aluminum heat sink) attached to the intake manifold.
Bob
04-03-2006 14:00:14
 Re: 6.5 GM diesel in reply to Blksmok, 04-03-2006 08:23:01
smok,
On what year are you saying the pump activates along with the glow plugs? I am NOT familiar with that, although, as I said previously, there have been some variations in the circuit... not trying to argue, just trying to verify something I must have missed, and have never heard of before.
Blksmok
04-04-2006 05:02:24
 Re: 6.5 GM diesel in reply to Bob, 04-03-2006 14:00:14
Bob..my 6.5 turbo diesel is a 1996. If you look at the wiring diagram the glow plugs and lift pump come on at the same time on cold starts. You should be able to hear the "clicking " noise of the lift pump for a few seconds on cold starts. When the engine is running, fan blowing, radio blasting...you can't hear it.
Tx Jim
04-04-2006 03:47:19
My 6.5 is a 2000 and glow plugs and lift pump come on at same time.Tx Jim
