B brake problem
BottomD
04-02-2006 16:26:16
A1944B Put new lining on the shoes the lining is tite to the shoe. No matter how I clamp them the the lining will not go back into the drum.When I took the old lining off it stoped 3"up from the bottom of the shoe.The shoes are tight to the casting at the top and tight to the lever shaft at the bottom.Does this mean that I have to cut the lining off 3" up like the other person did? P.S.the drum is clean.Thanks for your input.BottomD
P Browning
04-03-2006 03:48:32
 Re: B brake problem in reply to BottomD, 04-02-2006 16:26:16
Bottom D -- If you would email me, I will shoot back with a copy of FSB 147-S, page 1 which deals with your brake shoe. To answer your question about cutting it off like the prior lining was -- most likely this is just what you will need to do, and there is more. You may also need to install a replacement B2110R brake cam.
"The lining you have (in stock) is to be cut off to 1/2" of second set of holes and rivets installed, starting at the second set of holes on the cam operated end of brake shoe." (FSB 147-S, 5-15-44). (PatB)
CalJim
04-02-2006 22:45:28
Both Mike and Kurt are correct, Deere changed the size of the shoes with a Field Service Bulletin in early 40's I believe. They found the brakes worked better when they made the shoes shorter. For some reason most replacement shoes you buy are still full size. That being said,you still should have been able to slip the fullsize shoes inside the drum. Double check your adjusting pins and rollers, making sure the adjusting screw is backed off as Kurt said. Also check the position of the cam. CalJim
Mike M
04-02-2006 17:57:14
Cut them off ! That's the way they came from the factory. For some reason a full lining won't fit in those year B's.
Kurt_JDB
04-02-2006 16:55:31
Have you backed off on the brake adjuster all the way?
Kurt
Jason Z in MO
04-03-2006 13:05:36
 Re: B brake problem in reply to Kurt_JDB, 04-02-2006 16:55:31
I cut mine with a metal cutting disk in a chop saw. Use a grinder or the side face of the cutting disk to bevel the cut edge.
Worked really clean and real fast!
