ID on trailer plow
Tyler Kolbe
04-02-2006 15:30:31
I have a 3-16 trailer plow. Hyd. lift. Small rear tail wheel. Regular rim front wheels not spoked. It also has trip back bottoms. Would this be a 555H Model?
Tyler Kolbe
04-04-2006 19:47:51
 Re: ID on trailer plow in reply to Tyler Kolbe, 04-02-2006 15:30:31
I walked back by it before it got dark and it has the 1 1/2" x 1 3/4" solid beam diagonally across. Then I looked at Glen's 555 pix. And yes I would say it is a 555H. Thanks again.
Glen in TX
04-03-2006 23:58:24
A 555 4 bottom
Tyler Kolbe
04-03-2006 20:54:20
Thanks for the replies. I'll have to look at it again closer. I would like to get a picture but don't know when I'll get that done. But I went through the implement photos and Glen in TX F120 4 bt pix has the same trip bottoms as what I have if that helps at all for the time being. Thanks!
Glen in TX
04-03-2006 21:49:10
 Re: ID on trailer plow in reply to Tyler Kolbe, 04-03-2006 20:54:20
Ok, so it has safety trip standards like the F120. I can post pics of 55 or 555 later but I don't have anything on the 600 series plows but someone here will know more on those.
Bob Collins
04-03-2006 08:35:47
Could well be a 555H but might be something newer like john51 said too. You won't find any beam numbers on that plow but if the beam truss is a solid square bar that bolts diagonally across the beams it is likely a 555 or 666. The later F-600 series used a larger boxed (hollow) truss brace.
Glen in TX
04-03-2006 08:04:03
Post some beam numbers or part numbers from plow and/or pics here or at photo galleries to left at implement photos or help identify. You might also search photos there for other plows to match yours as several are on there.
John51
04-02-2006 16:37:04
Could be an F620H
