Battery charging on my 50?
JP JD50
04-01-2006 18:28:15
How do I get to the battery on my JD 50 to charge it? I know it is located under the seat in the battery box but I am unable to figure out how to get to it.
Thanks
Battery box
04-02-2006 13:26:40
 Re: Battery charging on my 50? in reply to JP JD50, 04-01-2006 18:28:15
Jack up the tractor and remove the rear left wheel tire and casting, This will get you up next to the battery box, Now have your buddy lift up the patted seat and the battery will be hiding in their.
that's hilarious
04-02-2006 20:28:53
 Re: Battery charging on my 50? in reply to Battery box, 04-02-2006 13:26:40
But it is a "padded" seat, not "patted"
johns48b
04-02-2006 04:41:54
if the fifty is positive ground you'll have to disconnect the battery leads before charging with a charger (positive side only)
billde
04-02-2006 08:27:54
 Re: Battery charging on my 50? in reply to johns48b, 04-02-2006 04:41:54
Please explain why you need to disconnect the battery cable?
55 50
04-02-2006 12:13:12
 Re: Battery charging on my 50? in reply to billde, 04-02-2006 08:27:54
Hi billde,
Good comment! I"d like to know, too. It"s more of that incorrect info that gets passed around on the internet. I have never disconnected a battery cable before connecting a charger to a battery.
55 50
04-01-2006 20:42:48
You must not have looked very hard at all!!!! This barely deserves an answer. SIMPLY LIFT THE SEAT CUSHION!!!!
