4020 pto leak
Ferd
04-01-2006 13:09:28
Pulled the rear pto quill out and the 540 rpm drive gear. Looked like the O ring on the idler shaft was leaking so pulled the idler shaft and all of the bearing rollers fell down. Now it looks like I need to pull the idler gear to get the rollers in place but the drive gear is in the way. Does it pull out with the pto shaft once the snap ring is released? Doesn"t seem to want to move. Manual says something about driving it out. Any suggestions would really be appreciated.
msb
04-01-2006 18:56:27
 Re: 4020 pto leak in reply to Ferd, 04-01-2006 13:09:28
Remove the front pto quill and see if you can find some snap ring pliers that will reach the front snap ring.I don't think it can be done,but its been so long,I forgot if it can be reached.Please let me know if you do it.
Unfortunately, if not, you have to split the tractor between the clutch housing and the transmission before you can get the PTO shaft out of the way of the idler gear assembly.There is that snap ring on the front of the pto gear that has to be removed before you can drive the pto shaft out.
Use some heavy grease like wheel bearing grease to hold the rollers in place when installing the idler gear.
Now is a very good time to check the pto brake and its operation.Also a very,very good time to replace the pto input shaft seal in the clutch housing.The transmission input shaft and the pto input shaft will pull out of the clutch asssembly exposing the rear pto input shaft seal.Also replace the seal on the front end of the pto input shaft while you have it out.Take care to replace the thrust washers in the correct place.Good luck.Its not a bad job.Just takes some time.bob
