JD 160 lawn tractor won't start
Nathan Schwartz
04-01-2006 11:26:38
I had tractor running,cut the grass,and when I went to start it again there was nothing happening electricaly. I checked the fuse and made sure power blade switch was off,and I had it in nuteral,but still no luck. Is there more than 1 fuse? that was all I could find.any help would be greatly appreciated.
greg miskow
04-02-2006 07:02:21
 Re: JD 160 lawn tractor won't start in reply to Nathan Schwartz, 04-01-2006 11:26:38
there is a problem with all 160's doing this. John Deere has a kit that installs a relay in the start circuit. The neutral switches get dirty and cannot carry enough current to engage the starter, a relay in the start wire solves the problem.
