630 wont stay running
jd2830
03-31-2006 05:43:07
My 630 won"t stay running unless the starter button stays pressed any ideas. Thanks in advance
John T
03-31-2006 07:14:06
 Re: 630 wont stay running in reply to jd2830, 03-31-2006 05:43:07
JD, I agree with Mike. On that 630 the starter push switch feeds unballasted battery voltage to the coil when depressed via a connection on the low output (To coil NOT from Ign switch) side of the Ballast Resistor. The Ignition switches IGN terminal feeds voltage to the other high input (NOT to coil) side of the ballast resistor.
As Mike indicates, if she runs ONLY with the start button depressed but NOT otherwise, the problems could be the Ballast Resistor is open or not wired correct or theres an open wire from the Ignition switches IGN output to the high input side of the ballast.
My first guess would be the Ballast is bad and became on Open circuit. Place a test lamp on the output (to coil) side of the ballast and when the Ignition switch is turned ON voltage should appear of around 6 volts if the points are closed and all is okay. If theres no voltage there but it does appear on the other input side of the ballast, the ballast may be burend and an open circuit. With the wires removed the ballast should show continuity of around 1.5 to 1.85 ohms. If an open (infinity) circuit appears across the ballast, shes burned open and needs a new ballast.
John T
Mike M
03-31-2006 06:32:07
That should have a bypass starting system. This lets 12V go to the coil when the switch is pushed then cuts back to 6v when released. You may have a bad resistor,a loose or corroded wire,if it was unhooked lately it may have a wire hooked on the wrong spot ?
A little probing with a test light should tell where you have power and where not.
