B front tire size with a 45 loader
MI-Bill
03-31-2006 05:13:14
I have a 1946 B recently resusitated with a 45 loader that I am using for landscape purposes? Moving piles of stones, wood and wood chips. The front tires must be nearly 40 years old. It was my fathers tractor. It appears the front tires might be 5.50 16?? What size tires would make it easier to steer? I am thinking that 6.50-16s would not sink in as much and perhaps steer easier with weight on. I have also noted that cars and trucks tend to steer harder with larger tires.
Gr8Bald1
03-31-2006 23:56:47
 Re: B front tire size with a 45 loader in reply to MI-Bill, 03-31-2006 05:13:14
You need to go with the 5.50 X 16 tire for proper fit on your rim. I thought I needed the 15 on my 51 B but they were way too small to fit on the rim. Maybe unstyled Bs took a 15? About the only choice you have to make is 1,2, or 3 rib tread. ! rib will give you great bite for steering but will do a number on your yard!
Mike M
03-31-2006 06:42:15
I think that model should have 15" tires on it.
I doubt you will find much that will fit under there and give any relief.
