4240 engine miss at high rpm
Organicfarmboy
03-30-2006 21:14:17
Hi all,
We have a 1982 4240 with about 5300 hours on the clock that has a miss at higher rpm's (1700 - 2100). Changed fuel filter, loosend one injector line at a time thinking it might be a bad injector but all six made the rpms drop slightly. Noticed a bit of fuel or oil leaking around the fuel pump on the engine block, can these go bad? At idle or low rpm's it runs smooth. Any ideas? Thanks...
Alex
Organicfarmboy
07-16-2006 00:00:07
 Re: 4240 engine miss at high rpm in reply to Organicfarmboy, 03-30-2006 21:14:17
Hi all,
Just a follow up on this problem...
Had the tractor sent to a shop, and they adjusted the valves, replaced the injector tips and the thermostats as it was not warming up properly. It sounded worse after that, and they had checked compession to locate possible bad valves, but they were okay. So we removed the rotary injector pump and sent it away to be overhauled, and after it was returned we were told it had water damage (assumming internal), but it runs great now!
Thanks to those who replied, and hope this may help someone!
Alex
ET
03-31-2006 07:42:16
I don't remember if that tractor used pencil injectors or not. If it does take the fuel return line off the top of the injectors and start the engine. A bad injector will dump a lot of fuel out the return side compaired to the rest of the injectors.
Mike M
03-31-2006 06:39:49
It that model has a rotary style pump loosening a line will make all drop pressure. So that may not tell you anything. I'd pull the injectors and have them tested. Won't hurt to pull the valve cover like suggested before and take a look ,but I'd also adjust the valves.
Catching a little problem now may save bigger troubles later. If an injector screws up they can take a piston out with time.
Shane S
03-31-2006 06:21:47
Organic,
If you loosened the injectors and it made a difference on all 6, it must be a compression problem. Don't know for sure, but it sounds to me like maybe a bad valve spring. Maybe the valves are floating or bouncing at the higher rpm, and compression is dropping. I would pull the valve cover and check the springs.
Good luck,
Shane
