!928 GP
Mike in Wi.
03-30-2006 18:40:05
Hi guys- looking at buying a 1928 JD GP stardard tread.It is a one owner on steel and rubber.It runs well but motor has never been touch just taken care of.Has not been painted so looks a little rough.Tin is straight.Any idea what it is worth?Thanks
paul o
04-01-2006 18:21:53
 Re: !928 GP in reply to Mike in Wi., 03-30-2006 18:40:05
The value of a 1928 GP can vary over a wide range, depending on how original it is. For example, does it have the low air cleaner (AC172), does it have a slant spark plug head, does it have the correct flat spoke front wheels, does the tractor match the serial number, etc?
Marty Z
03-30-2006 22:10:07
Depending on condition the price could range from $4000 to $6000 with a good serial tag. Check the verticle front spindles to see how much wear they have by giving the front end a couple of tugs. They seem to be a problem with the GP's that were not maintained.Front bearings and bushings are expensive. about $450.That GP is a special machine . Not many around. Look at how rare it is for one to pop up for sale on this board. I think I can send you some GP pics if you want. I have a 29 on rear steel and front cut offs, restored.
Marty Z
Curtice Ohio
