1951 MT Overheating
Doc in Texas
03-30-2006 17:42:05
I understand this tractor does not have a water pump and the cooling system works like a perculator. There is a round gizmo that says J&S carbutator co. Dallas Tx,this connects to the top hose of the radiator. Does this have any connection to temperature control. Also this tractor has no brakes, I have been told that it has wet brakes,what does that mean?
This tractor was handed down to me this year,it had been setting up for 12 to 14 years, I have it running and am using it sparingly, but would like to get it to the point that I could use it regularly.
Thanks,
Doc
Kurt_JDB
03-31-2006 04:42:53
 Re: 1951 MT Overheating in reply to Doc in Texas, 03-30-2006 17:42:05
Doc,
I understand from your message that you just recently got the tractor running. I would guess you may have changed or topped off the cooling system fluid. You should be aware that if you don"t mix the water and antifreeze before you pour it into a thermosyphon cooling system, the water/antifreeze will not circulate properly. This will cause overheating.
Solution is to drain fluid into some big buckets, mix it up, and refill.
You might also try running the tractor with a mix of water and washing soda in the cooling system to flush it out. My B service manual gives the procedure for this and mix. I will post it to you if you like.
Kurt
van robinson
03-30-2006 21:39:16
As mentioned, the J&S thing should be taken off if it is not in use. If the MT runs on gasoline, then it is not needed. For the cooling system to work properly, fluid passageways need to be clean and unobstructed. The radiator must be very clean also. The cooling system works by thermal action. Cold water settles to bottom, hot water rises. Since there is no pump to force the water to move, it has to rely on thermal action. If something is blocking or restricting the flow, then it has no choice but to overheat.
Hayfarmer
03-30-2006 21:10:22
Brakes on the MT, as mentioned, should not be wet. They are in a housing, one on each side, follow linkage. They are "self actuating". There are 2 metal plates with ball bearins between and some springs holding them together, and 2 brake discs on each side. Remove the housing and you can tell the problem, may be soaked with oil or may just be glazed over or maybe the balls or springs are gone or lining worn off the discs. They should work good when cleaned up or repaired.
Glen in TX
03-30-2006 19:04:22
Does it run on gasoline now or propane? Reason I ask that is because J&S made LPG systems and what you are looking at is probably a vaporizer/regulator for a LP system. J&S is long out of business and was bought out by Impco, makers of LP & natural gas carburetion systems. If it's just running on gasoline now you don't need that in there. Never seen a M with a LP system. The I&T JD-4 shop manual covers the M & MT tractors also.
Mike M
03-30-2006 18:55:54
That round gizmo sounds like some kinda aftermarket thermostat ???? I'd take it off.
Those are to have dry brakes. Yours may be wet with oil leaking onto them and maybe thats why they don't work.
