CONVERTING 2010 TO A NEG. GROUND SYSTEM???
MIKE T..
11-25-1999 08:24:41
I WANT TO PUT A HIGH AMP (55AMP) ALTERNATOR ON MY 2010, AND RACKING MY BRAIN HOW TO IT. MY BIG CONCERN IS THE STARTER, WHETHER IT'LL SPIN THE WRONG WAY..... .NOTHING ELSE MATTERS, COIL LEADS
CAN BE REVERSED,AS WELL AS BATT. CABLES,LIGHT BULBS DON'T CARE ABOUT POLARITY. VOLTAGE REG. IS
BUILT INTO THE G.M. ALTERNATOR.
HAS ANY ONE DONE THIS CONVERSION????? ????? ?????
Moye
11-25-1999 11:04:15
 Re: CONVERTING 2010 TO A NEG. GROUND SYSTEM??? in reply to MIKE T.., 11-25-1999 08:24:41
Mark, Robert's right. This converson has been done so many times. Check archives on how to do it. Tractor board goes into extensive detail. The starter will work even better and I've never heard of one spinning backward or burning up because of the conversion. Moye
ROBERT
11-25-1999 09:19:17
YES I HAVE
THE STARTER WILL WORK JUST FINE
USE A DELCO ONE WIRE
MAKING BRAKETS THAT LOOK RIGHT IS THE HARD PART GOOD LUCK ROBERT
