B Powertrol again
Doug L
03-30-2006 08:43:36
The manual says to use the same grade of oil in the Powertrol for a 1948 B as the motor. I currently have Napa brand hydraulic oil in the powertrol (before I read the manual) and it does not hold pressure. Could the lighter hydraulic oil be contributing to the lift bleeding down and should I replace it with 10W30 or 10W40? Several experts in this forum have already suggested that my powertrol has other problems then oil but I just wanted to make sure I had the correct oil in it as well. Thanks Doug
dbwillia
03-30-2006 09:07:56
 Re: B Powertrol again in reply to Doug L, 03-30-2006 08:43:36
I use straight 30 weight non detergent motor oil in my 1948 B John Deere power trol. I believe this is what the original manual called for. It works good. Dad had an A JD with power trol and that is all he ever used.
Doug l.
03-30-2006 16:37:58
 Re: B Powertrol again in reply to dbwillia, 03-30-2006 09:07:56
Thanks a million.
