70-730 pony tranny question
WeirdDeere
03-30-2006 05:38:21
While working on the pony of my 70, I discovered that the bushing on the very end of the transmission was worn a little...enough to make me replace it.
This bushing:
When I pressed the bushing out, I found that there was an oil passage behind it, which leads to the transmission gearcase. So it would seem to be set up to be lubricated. Just one strange thing....the bushing that I removed, and my replacement bushing have NO HOLE to let the oil through.
Did anybody else notice this and drill a hole in the bushing? I plan on doing that, I'm just wondering if too much oil would get through, and run down the side of the tractor, since there is no where else for the oil to go!
Brandon
carpenter
03-30-2006 06:13:43
 Re: 70-730 pony tranny question in reply to WeirdDeere, 03-30-2006 05:38:21
It may be that the brass is poures enough to seep lubricant through. Some brass bushings are made with this tendency enhanced I believe?
F-I-T
03-30-2006 07:15:51
 Re: 70-730 pony tranny question in reply to carpenter, 03-30-2006 06:13:43
Carpenter is correct. Those bushings, at least originally, were "Oil-Lite" cintered bronze, which weeped oil for lubrication via their pores. Imagine a kitchen metal pot scrubber compressed to about 3% volume. The tiny little gaps and crevices would continue to allow water to pass through. However, after years of use, many of the Oil-Lite bushings smear worn material and debris across and over the pores making the lubrication pretty spotty.
If you've decided to go through that pony transmission, do yourself a favor and replace the three bearings, the other bushing, the couple of seals and go through the overrunning clutch while it's apart. If you have pronounced depressions worn in the incline surfaces of the star wheel, you really should re-work that to get a smooth track for the rollers. It will make the action silky smooth!
Frank
F-I-T
03-30-2006 07:32:33
 As for the oil passage... in reply to F-I-T, 03-30-2006 07:15:51
Forgot about the oil passage comment....I think that's a just a short hole drilled to the upper right where you could apply 8 or 10 drops of oil everytime the cover was off. It might have even at one time includede a spring-loaded little cap to keep the oil in and the dust out, but don't quote me on that.
Frank
