3010 lift links
newtoJD
03-29-2006 19:33:45
I am trying to set up my 3010 3pt for a CAT-1 grooming mower but even with the sway blocks set for CAT-1 (narrow)the lift links measure 29 1/2 inches apart instead of 26 inches. I checked the part numbers on the sway blocks and they are the right ones. Any ideas?
Glen in TX
03-29-2006 22:15:03
 Re: 3010 lift links in reply to newtoJD, 03-29-2006 19:33:45
Make sure lift arms aren't screwed in all the way? I know some also have welded on another half pipe spacer to the lift arms next to the sway blocks for less slack in Cat. 2 position and then they won't go all the way in for Cat. 1. Or?? blocks are still turned wrong or upside down?
third party image
third party image
newtoJD
03-30-2006 09:13:07
 Re: 3010 lift links in reply to Glen in TX, 03-29-2006 22:15:03
I do have half pipe spacers welded on the lift arms but I thought those were from factory. Should I just cut those off?
Glen in TX
03-30-2006 09:48:14
 Re: 3010 lift links in reply to newtoJD, 03-30-2006 09:13:07
No, don't cut those off. Those half pipe spacers were factory but look at them closely to see if someone has cut and welded another half pipe layer over them to take out more slack. We did that on 2510 arms welding another half pipe over the one there already to take out slack when used in Cat.2 with a quick hitch but then when we wanted to remove the quick hitch and go to a Cat.1 we had to grind some off the sway blocks when in Cat. 1 position to make it work. It makes you want to convert all your hitches for Cat. 2 quick hitch and be done with it. 1 7/16" pump shaft works well for making quick hitch pins or putting a shaft all the across and welding on to convert the hitch for quick hitch. If sway blocks don't have spacers behind them and are in proper position you may need to unscrew the lift arms out longer yet to get more slack ?
newtoJD
03-30-2006 10:07:25
 Re: 3010 lift links in reply to Glen in TX, 03-30-2006 09:48:14
Thanks for the help. I'll look at those half pipes real close but a quick hitch would be nice.
