60 Carb question
JDR60
03-29-2006 19:23:30
i finished cleaning my duplex carb on my 60 and need to know what do i use to insert the two plugs on the sides covering the idle passages and do they have to be air tight. i have ruined a couple so far and am not doing something right. thanks in advance
Duane Larson
03-29-2006 21:22:25
 Re: 60 Carb question in reply to JDR60, 03-29-2006 19:23:30
JDR60,
They are 7/16" freeze plugs - Dorman still makes them but not everyone carries them. After beadblasting the carb, I put a VERY thin coating of Loctite PST (teflon pipe sealant) around the edges/sides of the cast cavity, lay the new plug over the opening, and tap the plug around the edge to put in place. When seated, I use a 1/8" punch and give a sharp rap to the center to expand the plug and give a tight fit. That is why it is hard to use the old ones, as they have likely been expanded during installation. If the fit is not fuel-tight, fuel will dribble out around the freeze plugs and make a mess.
I believe Robert's Carburetor Repair www.robertscarbrepair.com carries them.
