How to repair bearing surface of tranny shaft?
Kurt_JDB
03-29-2006 15:14:58
I finished tearing down the transmission on my "51 B today. I found various bad bearings, chipped gears and missing oil retainers.
I found that the bearing surface of the input shaft (B2435R) was galled, as was the bearing surface of the countershaft (AB3499R). Is there any way to fix these surfaces, or should I be looking for new parts?
Kurt
johns48b
03-30-2006 04:38:46
 Re: How to repair bearing surface of tranny shaft? in reply to Kurt_JDB, 03-29-2006 15:14:58
try marlyn smith at 712-489-2570 for used parts. good guy to deal with
2cylinderlp
03-29-2006 22:51:43
Sorry I don't know about sleeving the shafts in a transmission. Maybe someone else can comment on that.
CalJim
03-29-2006 22:45:38
Last year I purchased a Spray Torch from Napa. It hooks up to an oxy/acetylene torch, with some practice I have been able to build up shafts and build up worn down parts. It actually sprays different types of powders that are melted in to the worn piece. Then the pieces can be machined down to thier original size. CalJim
2cylinderlp
03-31-2006 18:51:00
 Re: How to repair bearing surface of tranny shaft? in reply to CalJim, 03-29-2006 22:45:38
I want to try this. Is it hard to do? What are the different powders for? I always build up the clutch pivot pin and the steering wheel shaft. But with my old Lincoln stick welder, the machinablilty isn't so good because of hard spots and slag inclusions. Lately I've been doing it with just the oxy-acetyline torch. I like the clutch pivot pins to be a real tight, almost press fit in the bushing. New parts don't fit that tight. I drill grease passages in the pin. For me it makes clutch operation much nicer and smoother. Do you have to preheat the part you are building up?
2cylinderlp
03-29-2006 16:10:41
I looked into this one time and found that it could be done. I think the metal had to be sprayed on and then it needed to be ground and hardened. The cost was very high. It was much more cost effective to go get used parts from a tractor salvage yard. There have been a bunch of B tranny parts on Ebay lately too.
Kurt_JDB
03-29-2006 18:12:06
 Re: How to repair bearing surface of tranny shaft? in reply to 2cylinderlp, 03-29-2006 16:10:41
I think I had heard somewhere that transmission shafts could be turned, and then sleeved. Do you know anything about that?
Kurt
