Crank shaft ? Will a late JD A fit in a JD 60?
Rich Loerzel
03-28-2006 18:15:48
A friend of mine has a very nice JD 60 with a bad crank, probably to bad to fix. He has a late model JD A parted out with a real nice looking crank. Will they interchange? If so, what other parts will he need to make it work?
JDBert
03-29-2006 11:05:59
 Re: Crank shaft ? Will a late JD A fit in a JD 60 in reply to Rich Loerzel, 03-28-2006 18:15:48
The "A" crank wont have the live power gear on the crank (clutch side). And I dont know about main bearings?
Glen in TX
03-29-2006 09:13:19
Like dab said it would only be very late As and very early 60s that it might work with? The A parts book doesn't even show the last later crank bearings used on them and you have to use the same ones from a early 60 parts book but I'm not sure the crank would be the same although main bearings would be.
dab
03-29-2006 08:50:10
I have heard of some parts from late -A-'s fitting early 60's but acording to my parts book the numbers for the crankshafts are totaly different which would leave me to believe that they are also different.
