49 B tappets
gmc ronnie
03-28-2006 14:44:02
the tappets have wear on the tips , where they push the valves open at the stem. can you grind them down flat or do you have to get new ones? thanks RON
Mike M
03-28-2006 19:14:09
 Re: 49 B tappets in reply to gmc ronnie, 03-28-2006 14:44:02
You can clean up the surface ,but do not go flat. Follow the curve on the face of them in the unworn part.
JD man in SD
03-28-2006 17:58:14
If you have a good shop near you they may have tool for there valve grinder to do this job i have a sioux grinder and do this to most rockers when rebuilding tractors you must take rockers of shaft to do this lol
Kent
F-I-T
03-28-2006 16:37:58
Ronnie:
I generally true the radius using my belt sander. At 1200 rpm engine speed, it only has to be close. I always felt that made them good for another 50 years.
Frank
gmc ronnie
03-28-2006 15:24:58
they are not worn to bad, but they do have wear on the tips, almost like a cupped grove .
Buddy Shields
03-28-2006 15:22:20
If they are not broken or wore severely, put on and adjust valve to specs.
