B Powertrol positions
Doug L
03-28-2006 13:39:44
Thanks to John T I figured out that the PTO must be engaged to operate the Powertrol lift on my 1948 B. Another question I have is that the lever next to the seat appears to have a forward middle and rear position. Forward lifts the 3 point and rear lowers it. When I lift my blade on the 3 point by moving the lever forward it returns to the middle position and then the blade gradually drops. Do I need to KEEP the lever in the forward position to maintain the lift or is it suopposed to return to the middle. If it is supposed to return to the middle then mine must be bleeding off pretty quickly because as I stated the blade drops pretty fast. Thanks again Doug L.
Doug L
03-28-2006 14:56:35
 Re: B Powertrol positions in reply to Doug L, 03-28-2006 13:39:44
Thanks to all. I will do some looking.
F-I-T
03-29-2006 06:52:30
 Re: B Powertrol positions in reply to Doug L, 03-28-2006 14:56:35
You know there is actually 5 positions:
1:Fast raise
2:Slow raise
3:Neutral
4:SLow drop
5:Fast drop
I installed all new o-rings, and honed the Powr-Trol cylinder, installed a new cylinder o-ring, gaskets where needed, and new power shaft seals while I was there, and I have a scraper box hanging on my 70D and it honestly has never sagged a bit. I used to park my 45W loader bucket raised over the work bench for two weeks at a time.
Now that's trusting your hydraulics! :)
Frank
Mike M
03-29-2006 07:13:28
 Re: B Powertrol positions in reply to F-I-T, 03-29-2006 06:52:30
Yes it sure is funny how the hydraulics of something 50 years old can stay up ,but yet on the "modern" new stuff they can't get them to do it.
buckeye al
03-28-2006 13:53:23
If all the parts are in proper condition the blade should stay in the raised position for weeks. I've seen 'em sit for months with the blade in the riased position.
Usually if it falls fairly quickly it is due to failiures of the piston seals or the rockshaft cylinder gasket. Since the fix is basically the same for both, that's the THIRD thing I'd do.
First I'd make sure all 4 of the O rings inside the remote adapter ports are good. They're cheap & all you need do is get a good O ring pick to get the old ones out & have some patience to put the new ones in.
After that's done, I'd connect a known good remote to the tractor and see if the remote holds position. Switch hoses from port to port & test again. If the remote holds with the hoses in either port, the valves are OK because the same valves hold the remote as would hold the rockshaft. If the remote holds, service the rockshaft cylinder and gasket.
Hope this helps.
Maark
03-28-2006 13:52:28
The position of your blade should stay in place, and the lever will return to neutral. If it is leaking down, either suspect the seal on the piston is bad or the gasket between the powertrol box and rear cover housing has a small tear in it.
