2130 JD
RCinNC
03-28-2006 11:41:35
I have a JD 2130 Mannheim 4x4 tractor. The 4x4 isn't working, my dealor said better to change to two wheel drive. What frontend would fit? where can I find one,is it worth it? It also has no power steering. I can not find the ser# in the usual places. Thank you for any help.
R. John Johnson
03-29-2006 06:50:57
 Re: 2130 JD in reply to RCinNC, 03-28-2006 11:41:35
I thought that all 2130's came standard with power steering? As to the FWD do you know if it is mechanical or hydraulic? Again, I am not familiar with this model, but they were common here in Canada, but I would think if it is mechanical there would be a driveshaft from the transmittion to the front axle, and hoses if it is hydraulic. Where are you located?
John
RCinNC
03-30-2006 05:31:13
 Re: 2130 JD in reply to R. John Johnson, 03-29-2006 06:50:57
John My tractor has power steering,Ijust forgot to say that, but it is not working. The 4x4 is hydraulic, dealer said controled by wire harness,it mit fix it,and it mit not. I live in western North Carolina.
Bison
03-28-2006 19:09:11
What is the problem with that axle
