1020 3pt
Ed Crawley
03-28-2006 11:10:01
I was using my box blade and the 3pt started coming up. I would put it down and as soon as I started it popped up again. Now it isnt doing anything. Checked oil and is fine. Help
Handsome Jim
03-28-2006 11:21:02
 Re: 1020 3pt in reply to Ed Crawley, 03-28-2006 11:10:01
Check your Rock Shaft or Depth and load control lever located below the seat on the right hand side. If it is in one of upper settings it won't allow the implement to work very deep. HJ
Ed Crawley
03-28-2006 12:02:42
 Re: 1020 3pt in reply to Handsome Jim, 03-28-2006 11:21:02
It is stuck in the up position and will not drop.
HTR
03-28-2006 19:38:01
 Re: 1020 3pt in reply to Ed Crawley, 03-28-2006 12:02:42
Is there any chance that your rate of drop screw is turned all the way in? That will keep them from lowering. When the lift was raising by its self, was the lever moving, or was the lever staying down, and the hitch coming up?
Ed Crawley
03-29-2006 03:43:17
 Re: 1020 3pt in reply to HTR, 03-28-2006 19:38:01
The rate of drop screw was not all the way in. And the lever was in the down position when it came up.
Handsome Jim
03-28-2006 15:35:59
Do you know which lever I'm talking about? Not the actual lever that operates the three point but under the seat there is a small flat lever that operates on a notched slide. It's not really hidden but if you're not familar with it, you can easily overlook it. If this is ground you've already covered, my apologies.HJ
Ed Crawley
03-28-2006 16:11:21
 Re: 1020 3pt in reply to Handsome Jim, 03-28-2006 15:35:59
Yes I know about that. Thanks
