430 Steering Problem
GaryK
03-28-2006 09:02:29
I am new to the JD board. Have been over at the MM site, as I am restoring one of those other colored tractors currently. I restored a JD 430W recently, and the only problem is that I have a wobble in the steering. This happens in high (4th in my tractor) gear. Since I take it on some tractor rides, this is a problem. I have replaced the U joint under the dash, adjusted the steering gearbox, and have adjusted toe in until I am blue in the face. Still have the wobble. Can anyone point me in the right direction? I should have mentioned that this tractor does not have power steering. Any help would be greatly appreciated.
Wayne in Tn.
03-28-2006 14:41:34
 Re: 430 Steering Problem in reply to GaryK, 03-28-2006 09:02:29
As mentioned, all those places can have wear and cause the wobble on the road. If you don"t want to rebuild everything, try running about 18 to 20 lbs. of air in the right front tire and about 40 in the left one. This will cause all the slack to stay on one side.
GaryK
03-28-2006 20:11:24
 Re: 430 Steering Problem in reply to Wayne in Tn., 03-28-2006 14:41:34
Thanks to everyone. Good things to check. Wayne in Tn - your response was very interesting. I have been on two 3 day rides and my strategy has been to drive close to the edge of the road where the slope of the road is the most. this also causes the slop to stay on one side. However, still pretty frustrating when the road is level. I will try what you suggested. Also FYI, when I bought my 430, it had a sticker from a dealer in Tn. I am in Ia and bought it at a consignment sale in Ia.
Thanks again EVERYONE
Gary
Ray
03-28-2006 13:18:05
Jack the front end off the ground and move the wheels back and forth,you"ll find the slop then.
Hayfarmer
03-28-2006 12:27:44
I had a wobble on my 430U one time, found the steering arm was a little loose where it hooks on the top of the spindle, tightened the bold and all ok. Other points could be tie rod ends or even wheel bearings. pull the hood and wiggle steering wheel to see where slack is. By the way I priced outer tie rod ends for mine a couple years back and they were like $85 each., inner ones are cheap.
Play farmer
03-28-2006 10:10:35
Hi JD, I'm not sure about the 430 but the MT (its similar) has a splined coupler between the gear and the lower end where the tie rods attach. Mine has alot of lay in the coupler. NOt sure if the wear is in the shaft or coupler but it could be the problem
Good luck and God bless
JD@Antique Acres
03-28-2006 12:09:50
 Re: 430 Steering Problem in reply to Play farmer, 03-28-2006 10:10:35
Yes, There are a number of wear points in that gear box that adjusting just won't solve, if they are worn badly.
GaryK
03-28-2006 20:20:47
 Re: 430 Steering Problem in reply to JD@Antique Acres, 03-28-2006 12:09:50
Thanks again. If it is still the gearbox, can it be rebuilt, or am I looking at a new one? I am not a highly skilled mechanic, but can usually figure out how to put something simple together by taking it apart. If it can be rebuilt, where can I find parts (I may regret that question).
Gary
JD@Antquie Acres
03-28-2006 09:25:11
Just a thought.... How are the tie rod ball joints?
Otherwise I inclined to say your problem still may be in the steering gear box. Even more so when you said you change the U-joint in the steering which can create a lot of slop.
