John Deere 2040 brake problem
Abrell
03-27-2006 20:17:04
I have a 1978 2040. The right brake cylinder stuck in. I removed the whole brake assembly, removed the ball and springs at the back of the right cylinder only and got the cylinder working freely. I put evertyhing back together and mounted the assembly back on the tractor. I filled the hydraulic fluid back to normal. Went to bleed the brakes and couldn"t get any fluid to pump out. I let tractor run for 20 minutes to warm up, but still no fluid ran into master cylinder. I took the bottom two plugs out of bottom thinking it might have vapor locked, still no oil. Anyone have any ideas what i did wrong?
