60 hyd. pump spec. needed
jdjack
03-27-2006 17:55:13
I have a hydraulic pump off a jd 60.
The idler gear bushing is worn out and the shaft is worn also. Does anybody know, or can post the specs on the shaft that is in the pump body? Is it the same as the "drive shaft". can that shaft be removed, and if so how do i get it out?
Thanks for anyhelp. If anybody has a pump that they know works good, and wants to sell e-mail me.
JDJACK
Glen in TX
03-27-2006 18:17:20
 Re: 60 hyd. pump spec. needed in reply to jdjack, 03-27-2006 17:55:13
Should be enough specs on that in a I&T JD-10 shop manual and even more info in a JD SM2011 Hydraulics shop manual. I suppose you have the camshaft driven pump?? For camshaft driven pump the follower or idler gear shaft O.D. should be .9994 to 1.000 and O.D. of drive shaft should be .8082 ot .8092. You want no more than .002-.003 over those on I.D. of bushings. If governor driven pump specs will be different also.
jdjack
03-27-2006 19:50:55
 Re: 60 hyd. pump spec. needed in reply to Glen in TX, 03-27-2006 18:17:20
my pump makes noises and will not produce enough pressure to lift loader. Will fixing the shaft and installing new bushing help?
Glen in TX
03-28-2006 11:13:24
 Re: 60 hyd. pump spec. needed in reply to jdjack, 03-27-2006 19:50:55
Gear thickness on the 50 & 60 camshaft driven pumps is .903-.904 . Don't think the bushings are available from JD and you will have to make them or resize some from bushing stock. These systems are not as of high pressure as later models so you can get by with some wear but not leaks. Pump rebuild may not be a cure all if you have other weak springs, leaky valves or a internal leak. The manuals can help you pin point and find those problems.
