JD 3010 weak brakes
MLZ
03-27-2006 17:28:37
I have a 3010 that I have used for years and as much as I wish it were a 4020, I still enjoy using it. It has NEVER had good brakes. You have to STAND on the pedals if you have a load on. I rebuilt the valves at the pedals and most recently took the axel off only to find the pads were in excellent shape.
This leads me to think it is poor pressure.? I know the pump is not in great shape, it is very noisy and when I start the tractor it takes about 10 seconds before it really starts chattering and lifts the lower links.
Where should I start to trouble shoot this? How much does it cost to rebuild the hydraulic pump? I'd like to correct this so others can operate the tractor too.
Thanks for any help!!
MLZ
Steve/IA
03-30-2006 11:26:30
 Re: JD 3010 weak brakes in reply to MLZ, 03-27-2006 17:28:37
I had my 3010 main pump rebuilt, stroke valve replaced, bleed line from main seals added to prevent future blown seals, and a new pump coupler for $2200 at a JD dealer. Mine is a wide front so the front axel needs to be dropped so the pump can come out which added some labor cost.
Bob
03-28-2006 07:54:22
Verify that the hydraulic system pressure at one of the remote couplers is 2100 to 2250 PSI after the tractor has run a bit, and the 3-point is working.
If you have good system pressure, the brakes should work. If the hydraulic system pressure is way low, that would explain the weak brakes.
Have you checked the internal suction screen down in the bottom of the rear housing?
The internal tranny pump/charge pump moves oil ahead from the rear sump to the oil cooler, and keeps the oil cooler full of oil for a reserve for the main, front pump. A quick check to verify if that pump is working is to disconnect the large steel line at the LH side of the tractor that goes forward from the valves near the hydraulic oil filter, then crank the engine over. There needs to be a good flow of oil going forward from the tranny pump to the cooler, if not repair that first.
If there is a good flow of charge oil, and poor system pressure and flow, the main pump will likely have to be pulled and OH'ed.
If you are going to have this tractor around, and intend on doing any work on it yourself, a Deere factory shop manual is ESSENTIAL. It will have detailed troubleshooting charts, and a color-coded oil flow diagram.
They are pricey, but at today's labor rates, you'll quickly recover the cost.
Call Deere @ 1-800-522-7448, with credit card in hand, for a factory manual.
MLZ
03-28-2006 10:06:30
 Re: JD 3010 weak brakes in reply to Bob, 03-28-2006 07:54:22
I do have the cheaper IT manual, but have been using the 4020 JD manual that I have. I guess I"ll have to bite the bullet on a good manual for this 3010 too. Thanks for the #.
One of the problems I have run into is that IT tells me to check the pressure at the brake supply line, which this tractor does not have, as shown in the book (probably as it is found on a 4010 or 50??). So, as you said I will be able to hook to the remote lines and get that reading?
Where is this screen which may need to be cleaned; behind the big plug, on the rear side of the filter housing? Again the manual I have says nothing about that screen. I don"t think i loked in the 4020 manual on that one.
The steering and the lift arms are both jumpy at start up. This made me think it was not the priority valve. Is there much hope that all I will need to do is turn that screw in on the pressure pump?!
Another symptom/s of the problem is that the detents don"t kick out. I use the tractor on my small round baler a lot and have to remind myself to pop the lever back up or down when I am dumping a bale. Having let it in the down position it overheats the tractor and hogs power. Also, it will drift in one direction, allowing the latch on the baler to open while the levers are not enguaged, or lift the rake off the ground while I am raking. It is not fast, but it is leaking past.
Thank you for all your help!!
MLZ
Bob
03-28-2006 14:32:31
 Re: JD 3010 weak brakes in reply to MLZ, 03-28-2006 10:06:30
"One of the problems I have run into is that IT tells me to check the pressure at the brake supply line, which this tractor does not have, as shown in the book (probably as it is found on a 4010 or 50??). So, as you said I will be able to hook to the remote lines and get that reading?"
There HAS TO BE a supply line from the up above, down to the brake valve. I don't have access to a 4010 at the moment, just have a 4020 around, or I'd go look. The priority valve keeps all the oil back for steering and brakes, until it's pressure is met, and then allows oil to the selective control valves, so having the correct pressure at a hydraulic outlet is a good (but probably not 100%) indication the front pump is working, and since the steering and brakes have first priority at the oil, they should be working, too.
"Where is this screen which may need to be cleaned; behind the big plug, on the rear side of the filter housing? Again the manual I have says nothing about that screen. I don"t think i loked in the 4020 manual on that one."
The screen, #39, is behind the sideways-facing plug low down ahead ot the final drive.
Third Party Image
"The steering and the lift arms are both jumpy at start up. This made me think it was not the priority valve. Is there much hope that all I will need to do is turn that screw in on the pressure pump?!"
A bad check valve, #34 and #35 in the diagram above or a bad transmission pump #40 can cause lack of oil to the front pump at startup, causing the jumpiness, as well as the front pump itself.
"Another symptom/s of the problem is that the detents don"t kick out. I use the tractor on my small round baler a lot and have to remind myself to pop the lever back up or down when I am dumping a bale. Having let it in the down position it overheats the tractor and hogs power. Also, it will drift in one direction, allowing the latch on the baler to open while the levers are not enguaged, or lift the rake off the ground while I am raking. It is not fast, but it is leaking past."
Providing the system pressure is correct, you have a detent problem inside the selective control valve(s) up under the rear of the hood.
Also, the drifting of the hydraulics is due to miss-adjusted, worn, or damaged poppet valves and seats in the selective control valve(s).
donmyeil
03-28-2006 07:45:39
check system pressure , should be 2150 to 2250 psi. then try bleeding the brakes. if steering is ok then have the brake valve gone thru by somebody that knows how to do it. could be some parts missing.
MLZ
03-28-2006 10:10:53
 Re: JD 3010 weak brakes in reply to donmyeil, 03-28-2006 07:45:39
I have not done the pressure test yet, but I think that is where the problem is. When I rebuilt the brake valve I did a through job, using a mic and am pretty certain that I put all the pieces back in, and am wondering what could possible be missed!
Thanks for your help.
MLZ
4010guy
03-28-2006 07:12:26
pull the cover off that the seat sits on over the rearend, thear is a small gear pump that feeds oil to your front pistin pump,i have seen the gears break or the pipe that feeds the pump on rair occ. has come lose---or you just need to rebuild your pistton pump---then thears the priority valve under the cowl that can stick..gess i would check that gear pump first...gotta start somewear..good luck & have fun as you will get to it evecheley!
