B TRANSMISSION QUESTION
homerd
03-27-2006 15:38:11
WE ARE RESTORING A 1943 B AND WE TOOK THE GEAR SHIFT MECHANISM OFF TO CLEAN IT UP AND ARE HAVING A PROBLEM GEING IT BACK ON SO THE GEARS CAN BE SHIFTED. WHAT AND HOW DO WE GET IT BACK CORRECTLY? THANKS HOMERD
jd b puller
03-27-2006 19:57:55
 Re: B TRANSMISSION QUESTION in reply to homerd, 03-27-2006 15:38:11
That's easy. Just have your miniature trunk monkey crawl inside the trans and let him do it for you.
Another option would be to slide the shifters so that it's in nuetral. Note where the high/low gear is. It'll be the one on the top shaft closest to the belt pulley. Put the gear selector in nuetral dead center and you should be able to get a flashlight in there and watch it go into place.
