2010 JD hydraulic oil questions
Jak
03-27-2006 11:15:12
How much rear end oil does it hold?I have to change it for a guy and so far I have a five gallon bucket of hydraulic oil.Is there a plain ole plug to drain it underneath?Does it have a filter anywhere?I have books but not for this tractor.Thanks for any help guys.Jack(TN).
billde
03-28-2006 09:32:24
 Re: 2010 JD hydraulic oil questions in reply to Jak, 03-27-2006 11:15:12
Jack, under the trans in line with the clutch pivot is the drain plug. The filter is the 3 bolts on a plate behind and above same pivot point.
HTR
03-27-2006 18:12:57
Don't forget the final drive housings, and the PTO gear case are separate from the transmission. They need to be drained and refilled also.
Tom in Mo.
03-27-2006 17:22:34
Hi Jack, The service manual from John Deere is SM-2035 and the Operator Manual is OM-T19263T. Everything you need to know about servicing the 2010 is there. A new filter is critical to the good performance of the 2010 hydraulics. Tom
billde
03-28-2006 12:06:58
 Re: 2010 JD hydraulic oil questions in reply to Tom in Mo., 03-27-2006 17:22:34
there are 3 service manuals for the 2010 and numerous operators manuals. you have to know the style and serial number to get the correct manuals.
