B hydraulics
Doug L.
03-27-2006 07:38:55
I have a 1948 B that I recently rebuilt after many years. Tractor is great so far but the hydraulic lift does not work. It is full of clean hydraulic oil (Napa brand) but when I move the lever next to the seat into the forward or backward position nothing happens. I can not hear anything from the rear (pump is mounted behind the seat) that sounds like it is trying to work either. Where do I start to determine what is wrong with it? I belive the manual says this is a Powertrol system. My knowledge of hydraulic systems is limited. Is there something else I need to do to activate the pump? Seems like that would be obvious but I do not see anything to do that. Thanks Doug
Dan-Bee
03-28-2006 22:23:52
 Re: B hydraulics in reply to Doug L., 03-27-2006 07:38:55
The clutch needs to be engaged for the hydraulics to work.. If having the clutch engaged is not convenient, then you need to try to find a live pump,which mounts behind the distributor.
John T
03-27-2006 08:29:01
Doug, Hydraulics "aint my cup o tea" so I can only offer preliminary info: First (PTO has to be engaged n turning you know, its NOT like hydraulics) for the rock shaft arms to rotate so they might lift an inplement like cultivators etc. you have to have the correct Power Trol Diverter Plugs inserted into the rear of the valve body which diverts hydraulic oil flow the correct direction to operate the rock shafts versus diverting flow for remote hydraulic cylinder operation via the rear hydraulic hose couplers.
Its possible to have one of those adjustable upper hydraulic plugs with an adjustable valve on top under the outer cap, otherwise you need the correct set of the plugs to changeover from remote cylinder operation to rockshaft lift operation.
I think FIT has a picture he can post showing those plugs and the ones you need to switch from rockshaft to remote hydraulics.
John T
