1010 clutch spring adj?
lloyd in sc
03-26-2006 14:09:24
manual says to adj fingers to 1 3/16 " from flywheel mounting pad. OK, how do I measure this? If you can help give me your ph # & i'll call so it won't cost you anything. thanks lloyd
Bob
03-26-2006 17:56:40
 Re: 1010 clutch spring adj? in reply to lloyd in sc, 03-26-2006 14:09:24
Make a finger height gauge out of sheet steel.
Here is a diagram of a shop-made gauge for an "N" series Ford.
Third Party Image
Alter the 12.25" overall dimension so the outer "feet" match the machined area on the flywheel where the pressure plate sits, and alter the 2" finger height dimension to the 1-3/16" you require.
I made one a couple of years ago to set up a 2010, the dimension you need sounds the same, I can't recall if they use the same clutch. If so, you could borrow the tool for the cost of postage, and then send it back.
lloyd in sc
03-26-2006 18:54:35
 Re: 1010 clutch spring adj? in reply to Bob, 03-26-2006 17:56:40
Thanks, The problem I had was figuring out where to measure from. I just finished cutting out a jig like the one you have. Thanks for the offer of a loaner anyway. I ended up taking the flywheel off & reassembling everything using a shop press to depress the springs enough to adjust it out. I thank you the reply as not many folks work on 1010s on here. lloyd
