JD 40 wiring dumb question
mike's600
03-26-2006 12:53:55
New to JD 40's with positive ground. My question is the proper wiring of the coil to dist..Does the wire comming out of the harness go to the positive side of the coil, and the negative wire to the dist.? Or is it the other way? Thanks
jCarroll
03-27-2006 04:22:22
 Re: JD 40 wiring dumb question in reply to mike's600, 03-26-2006 12:53:55
You might check out www.jd40.com for lots of info on the 40 series tractor.
donmyeil
03-26-2006 13:54:31
the wire to the distributer reflects the ground,in your case pos. to the dist.
mikes 600
03-26-2006 14:06:35
 Re: JD 40 wiring dumb question in reply to donmyeil, 03-26-2006 13:54:31
thanks
