4010 injector oil leak
c.r
03-26-2006 12:30:15
Just rebuilt the motor on a 4010, and now im running the tractor and the number 6 injector seems to have what appears to be engine oil runing out around it more from the injector hole rather then the injector. i have washed it off twice and it came back twice. Could it be a crack in the head?
donmyeil
03-26-2006 13:52:50
 Re: 4010 injector oil leak in reply to c.r, 03-26-2006 12:30:15
Probably dirt in the injector hole or possibly an extra washer in there. Pull the injector and clean it. While the injector is out put it on a tester and see if the nozzle tip barrell itself is leaking.
c.r
03-26-2006 14:44:13
 Re: 4010 injector oil leak in reply to donmyeil, 03-26-2006 13:52:50
i had the injectors sent out and were rebuilt but i will pull the one out and see if i can see anything else wrong ie two washers , thanks
