Long Stoke A crank in an Unstyled A
Alan Dewsnup
03-25-2006 19:53:04
I plan to install, a later styled long stroke "A" crank, in an unstyled "A". Would someone, who has done this retrofit, please respond so I can benefit from your experience and not learn everything the hard way. Other questions; what are the best rods to use? Where is the best place to get aluminum pistons? Does the hand start flywheel fit ok? I have a Hysler head on this tractor now, will using this head with the longer stroke crank make this tractor hard to hand start?
Thanks for your responses.
Alan
DSK
03-26-2006 12:18:48
 Re: Long Stoke A crank in an Unstyled A in reply to Alan Dewsnup, 03-25-2006 19:53:04
The crank swap is fairly straightforward, no clearancing required. I assume you are going to install the A2360R crank, which has the right end for the handstart flywheel. I would also install the A2449R flywheel to keep everything in balance. Use the A2344R connecting rods. These have a 1/4" larger wrist pin hole than the unstyled rod. {1 3/4}. Hinrichs Repair sells aluminum piston kits for most 2-cyl. JD's.{815}778-1900 or {815}499-6580. These pistons are M&W remakes and will have about 6.5 to 1 C.R. If your tractor is properly tuned, you should have no problem hand starting it.
