730D Will not idle.....surges
Rusty G
03-25-2006 17:22:29
Have a 730D that will not idle, you can start it up, and after a minute the rpm's start gradually getting faster and faster. The pumps and injectors have been rebuilt, and work just fine in another tractor with no problem. Have even changed the complete governor off another tractor and it still does not help. Any ideas?
F-I-T
03-25-2006 18:08:23
 Re: 730D Will not idle.....surges in reply to Rusty G, 03-25-2006 17:22:29
Did you swap the injectors as well when you put the pumps in the other tractor where they ran well? My thinking is that maybe there is a severe injector by-pass leak and the return is sufficient that when it is vented into the air intake it is causing the higher than normal operating speed. Since any leak-off fuel is not re-routed back to the pumps, leak off could cause a run away.
Frank
Rusty G
03-26-2006 06:03:29
 Re: 730D Will not idle.....surges in reply to F-I-T, 03-25-2006 18:08:23
FIT,
There is no fuel coming from the bleed lines, thought of that too, took them out of the head and ran it and watched and no fuel comes out of them. Ive really been scratching my head on this one.
F-I-T
03-26-2006 11:42:10
 Re: 730D Will not idle.....surges in reply to Rusty G, 03-26-2006 06:03:29
Is it getting engine oil into the combustion chamber from any source? When it gains speed, does the smoke change color or smell?
CFWelles
03-26-2006 05:32:45
Frank,
Please amplify if you would. Bypass goes back to fuel tank. How does it chance getting into air intake? Also, haven't tried it yet, but I rebuilt the governor on my 730 after just going into it to replace nylon tach gears. Found a weight had thrown. Anyway, it started up pretty easily after I put it all back together, but she lopes at slow speed. My take on this was that I did not get the tension spring in the throttle rod set with proper tension allowing the governor weights to move the fuel setting too easily. If it won't throw too much oil out, intend on starting it when I get a nice day up here in PA and just unlocking nut and adjusting tensioning to try and get surging to stop. Only surges at idel. When throttle up she is steady. Am I on right track. Your explanation seems to be only plausible cause as throttle is not moving. Just would like you to amplify on it as I am missing something. Maybe fellow with problem is not understanding your explanation completely as well.
F-I-T
03-26-2006 11:53:58
 Re: 730D Will not idle.....surges in reply to CFWelles, 03-26-2006 05:32:45
...I rebuilt the governor on my 730 after just going into it to replace nylon tach gears. Found a weight had thrown. ...put it all back together,...lopes at slow speed.... If it won't throw too much oil out, intend on starting it...and just unlocking nut and adjusting tensioning to try and get surging to stop. Only surges at idel....
I just made this adjustment on a 70D STD that has the upgraded governor speed control spring/rod/disk/locknut. I ran it on the dyno and it did not toss but a little spray of oil. I see this adjustment as re-positioning the governed speed band up or down, but it can not hurt to try. If the spring/disk/nut was too loose then the governor might hunt which would be constantly opening and closing the rack. You might want to watch the rack motion and see if it is bouncing back and forth at low speed. Maybe the rack return spring at the right hand end is broken in half and there isn't enough to pressure to keep the rack from bouncing.
I take it that the loping was not present before you torn it down? While it is loping at low speed, loosen one and then the opther injector lines to see which side injector is not putting out. It could have a slight occlusion in the nozzle that is showing up as poor spray at low speed and low fuel volume. Sounds like one injector is putting out less than the other for some reason.
Frank
CFWelles
03-26-2006 16:29:09
 Re: 730D Will not idle.....surges in reply to F-I-T, 03-26-2006 11:53:58
I appreciate the comments. I think the spring may be loose as I forgot to mark the spring tension in terms of threads of engagement on the rod during dissasembly. It did not hunt before teardown. Also a mechanic who I think knows his stuff at a local dealer....he has three or four of these tractors and with his dad still farms a small dairy with them....told me to check the injector timing. He told me this after I told him that I had replaced a pitted pump follower wheel during the rebuild. This timing goes along with your comments on a possible imbalance between injector timing and/or output. I will look into this as well. My guess is that the spring tension is just a little too light allowing the crude control system that is the weights to oscillate without any dampening. I am looking forward to going through this exercise.
CFWelles
03-26-2006 05:40:03
Maybe I need to go back to layout. Bypass I am thinking of is off injection pump supply from transfer pump. You are saying that injectors themselves have a bypass to air intake? Makes me wonder why poster doesn't see rmp's ramp for a minute or so. Would think this problem would occur right away from your source.
F-I-T
03-26-2006 11:06:24
 Re: 730D Will not idle.....surges in reply to CFWelles, 03-26-2006 05:40:03
"You are saying that injectors themselves have a bypass to air intake"
Unless they are plumbed dramatically different from the 70 and 720's D's I've had open, the leak off pipes are NOT routed in a closed loop back to the tank, but instead dump the fuel into two small ports in the head which route the fuel into the respective sides intake ports for induction and re-burning.
Frank
Chuck730D SE
03-25-2006 17:32:20
Is it gaining RPM and the throttle lever is not moving forward? If so, check for something loose in the governor control.
Only two things will allow it to gain RPM, the throttle moving forward or it is somehow getting more fuel. Hard to diagnose at a distance.
A 730D will surge or lope a little if it is set under rated slow idle, it is just the way it is timed.
Something has to be allowing more fuel in for it to gain RPM.
Rusty G
03-25-2006 17:35:40
 Re: 730D Will not idle.....surges in reply to Chuck730D SE, 03-25-2006 17:32:20
The racks are not moving, even secured them in place so that they would not move from idle position. So the pumps are not changing, and the throttle arm is not moviing either. Nothing moves and and the rpms still ramp up to like 12-1300.
Chuck730D SE
03-25-2006 17:38:23
 Re: 730D Will not idle.....surges in reply to Rusty G, 03-25-2006 17:35:40
The fuel flow is increasing somehow, that is the only thing I can think of that will make the RPMs go higher.
Could it have a restriction somewhere and the idle is actually set higher than you think?
