G Questions
Travis_G_JD
03-25-2006 12:13:48
I bought a 1953 G that was slightly stuck, I was toald to put brakefluid in the plug holes, and a chain with a bar on it through the flywheel and try to get it loose . After alot of pulling on it I got it loose, but there is no compression now. Where do I start? and what do I do? Any and all advice appreciated Thanks, Travis
Bob
03-25-2006 12:22:21
 Re: G Questions in reply to Travis_G_JD, 03-25-2006 12:13:48
Likely, you have stuck valves and possible damage to the valve train from turning it over with the valves stuck.
Take off the rocker arm cover, and see what's happinin' in there.
