Couple JD R questions
Jeff NwOH
03-25-2006 08:38:40
Getting ready to paint my R. Trying to get all the leaks sealed up etc.. Likes to leave an oil spot on the floor under flywheel. Parts book shows an oil slinger on that side. Do those tend to dribble a little or is there something to adjust or that wears out? Don't want to pull that flywheel if thats normal. Also either my instrument panel or the dash panel below it is not original. Inst panel has 5 holes to mount to dash but dash has 7 holes. Which is correct for a 1950 ser no 46xx?
Skyhawk Greg
03-26-2006 19:12:31
 Re: Couple JD R questions in reply to Jeff NwOH, 03-25-2006 08:38:40
Jeff, I don't really know anything about the R, but if it has any similarity to a B, then there is a cork seal that is easily replaced just inside the casing behind the flywheel. It should still be available from the JD dealer. Be sure to use a feeler gauge to make sure the casing has clearance all around the rotating shaft. Good Luck! Greg
