4440 antifreeze down in oil pan
Roger h
03-25-2006 07:14:34
Anyone know the most common causes for this problem? I'm hoping for just a head gasket but my luck it will be something more major, Any other ideas? Thanks...Roger
twopop
03-25-2006 16:32:43
 Re: 4440 antifreeze down in oil pan in reply to Roger h, 03-25-2006 07:14:34
I would bet on # 6 cylinder sleeve leaking,due to electralisis(sp)the 466 seems to be affected more than the 404
donmyeil
03-25-2006 14:12:51
First thing I would do is rebuild the water pump. Its gear driven off the camshaft gear and will run coolant into the oil. Look close under the pump for a water stain as there is a drain hole for the seal there which is usually plugged with dirt,and as a result the coolant goes on into the oil.
Roger H
03-25-2006 14:40:14
 Re: 4440 antifreeze down in oil pan in reply to donmyeil, 03-25-2006 14:12:51
No the water pump is NOT driven from the camshaft, I have rebuilt the pump from my 7720 combine & they are the same 466 motors as the 40 series tractors.
donmyeil
03-26-2006 14:26:59
 Re: 4440 antifreeze down in oil pan in reply to Roger H, 03-25-2006 14:40:14
I stand corrected. thats what happens when you engage the brain and its not working. Anyhow I would bet on head gasket but once you open it up you need to be prepared to go all the way if you dont see any head gasket damage or head bolt problem.
buickanddeere
03-25-2006 10:54:55
Try a ph test kit in the coolant. It maybe old and turned acidic then ate through everything.
DSK
03-25-2006 09:13:37
More than likely, the sealing O-rings on the bottom of the sleeves have failed. Although you can replace just the O-rings, it is usually recommended to install new sleeves and pistons because the old sleeves are usually corroded in the sealing area. I have seen some 4010's and 4020's where the o-ring grooves in the block were also corroded to the point where the block had to be replaced, but this is unusual. Although the O-rings won't last forever, some cases like this can be prevented by periodic cooling system maintenance.
Roger H
03-25-2006 09:31:37
 Re: 4440 antifreeze down in oil pan in reply to DSK, 03-25-2006 09:13:37
I know what you mean on the 4020 blocks, I had a '69 4020 that the block was ate up at the bottom of the sleeves, I hope I'm not in the same situation now.
Lee B
03-25-2006 17:00:20
 Re: 4440 antifreeze down in oil pan in reply to Roger H, 03-25-2006 09:31:37
My guess would be just this situation but rating just barely marginal? Especially if only the first half cup of oil drained was green and the rest of it was deep black indicating that the leak only happens when the engine is off and very cold. Perhaps leaking only on the coldest day of winter to boot.
I would try stop leak first since it's cheaper than an overhaul. They make a stop leak based on Water Glass that can't be used with a water system filter/conditioner, but it's not supposed to be left in the system anyway, so one could use an old filter for the treatment. At any rate, the water glass type of stop leak works amazingly well as it does set up. I can't imagine how that is done exactly (the process), I do know that it fixed a huge squirting hole permanently.
