Brake rivits
Chuck730D SE
03-25-2006 07:05:27
I am replacing the brake shoes on a JD 70. There are 10 rivets to the shoe. Anyone have a quick means of mushrooming these rivits? Is there a hand operated machine out there that will do this quickly?
Kurt_JDB
03-26-2006 05:29:10
 Re: Brake rivits in reply to Chuck730D SE, 03-25-2006 07:05:27
Chuck,
I have had great success using a transfer punch to set the rivets on the brake shoe. Maybe the 7/16 punch? The shape of the end of the punch is such that it will evenly mushroom the rivet rigt over with just a few taps. Trick is not to hit it to hard or get it too tight, as you can crack the lining.
Kurt
Dan in Ohio
03-26-2006 12:31:18
 Re: Brake rivits in reply to Kurt_JDB, 03-26-2006 05:29:10
Kurt, I agree, the use of a transfer punch makes this is quick job. A whole set of these only cost about $10. I have done at least 3 sets this way and not had any problems.
torch
03-25-2006 18:20:23
you could have got the kit from a deere dealer for a small fee of 32.00 and if you made a good impression. you would have got done cheap!
Chuck730D SE
03-26-2006 03:32:11
 Re: Brake rivits in reply to torch, 03-25-2006 18:20:23
I already had the brake linings in a group of NOS parts that I bought for cheap. The riviter is about $15.00 and should last along time.
That is cheaper than anything connected with visiting a JD dealer. It cost more than that just to pull up in their parking lot.
torch
03-25-2006 18:19:53
41Jdb
03-25-2006 10:08:31
It only took me 20 minutes to rivet them on by hand. I clamped a bolt in the vice and put the pad face down on that then started to mushroom the rivet with a prick punch and then took a bigger punch and finished peening it over. It doesnt take to long ang can just be another fix you did yourself. AL
Glen in TX
03-25-2006 09:38:18
Like Pat said the easiest is to visit a NAPA or brake or truck and clutch place and let them do it. Some others have even had some done with the bonded facings and liked them too. Can find the rivets at several places or order from mcmaster.com . If you insist on finding yourself a riveter here is a link to a simple one.
Chuck730D SE
03-25-2006 12:43:33
 Re: Brake rivits in reply to Glen in TX, 03-25-2006 09:38:18
That is exactly what I was looking for, many thanks for your reply and the information.
P Browning
03-25-2006 07:41:49
Chuck -- the quickest and most economical way I can think of is to carry the shoes and new facings to a local "clutch & brake" type shop where they have the needed equipment and skill to do it without hurting the facings -- which (as you know) are brittle! (PatB)
