4440 PTO lever
musicman44
03-24-2006 18:19:56
To keep the pto engaged I have to tie the lever forward or else hold it forward. I tried adjusting the linkage by adjusting yoke on bottom end of rod. Shorter or longer, neither helped. If it matters this is a quad-range 4440.
The I&T shop service manual for this is no help.
Thanks.
JD man in SD
03-24-2006 19:23:31
 Re: 4440 PTO lever in reply to musicman44, 03-24-2006 18:19:56
Use your I&T manual and remove pto, clutch opr valve on left of flywheel housing. on back side of valve there is a lever on the shaft that operates the pto the piston that holes in gear pushes on it they bent over time replace it lol Kent
dp in nd
03-24-2006 18:38:40
on a quad the lever is held in by hydra pressure,there is something wrong in the control valve or hydra system. Dale
