Gear damage
Kurt_JDB
03-24-2006 14:22:39
I am in the process of tearing down the transmission on my "51 B. Many of the bearing and gears are very damaged. I plan to seek replacement gears.
I can see the big drive gear of the differential, and it looks very good, except one tooth is about 1/3 broken off. Should I replace this too?
Any good sources for used tranny parts out there?
Thanks,
Kurt
Len Bull from NC
03-25-2006 14:12:19
 Re: Gear damage in reply to Kurt_JDB, 03-24-2006 14:22:39
Kurt:
I live in Raleigh/Durham also. Contact Mark Rice at: [email protected]. He has worked on a lot of John Deere tractors also, has a 40 carwler, and several 2 cyl tractors on the home farm in MO, and I think might have some advice. I have a 50 A on a friend's farm in Oxford.
LEN BULL
JD man in SD
03-25-2006 05:15:47
Kurt ware do you live. I have the diff. that you need Thanks Kent
Glen in TX
03-24-2006 21:11:31
Kurt, Not sure if these fit your B but I have a NOS B1862R countershaft idler gear and B1911R shift fork. More yards: adeptr.com (parts then state)
Kurt_JDB
03-25-2006 05:48:11
 Re: Gear damage in reply to Glen in TX, 03-24-2006 21:11:31
Glen,
Thanks for the offer. I do need the countershaft idler, however the part for my late syled B would be B 2417 R.
Glen in TX
03-25-2006 09:32:24
 Re: Gear damage in reply to Kurt_JDB, 03-25-2006 05:48:11
Ok Kurt, I thought it wasn't right one & those are the only B trans parts I have now. Will let you know if something else turns up.
2cylinderlp
03-24-2006 19:22:45
third party image
I had a similar find when I opened up the transmission on my current 730 project. I decided to replace the big differential gear and had to find a used part. It shouldn't be too hard to find a used differential for your 1951 B. I put a link below for a list of salvage yards.
There are a number of salvage yard advertisers in Two Cylinder and Green Magazine. Or just do a Google search for tractor salvage yards. Or put a wanted add on this site in the classifieds section.
My 2nd/5th gear was bad also and I now have a heightened appreciation for making sure the clutch pulley is stopped before shifting gears. My bearings all looked pretty good.
A JD 50 that I did a lot of work on last year had severe pitting corrosion in all the bearings. It would be quite similar to your B. The lower shaft and double gear had to be replaced because of pitting in the roller bearing area. The input shaft had to be replaced also, again because of poor condition in the bearing area. In spite of the poor condition of the bearings, all gears still functioned normally. But from that work, I also have a heightened appreciation for keeping water out of the transmission. I'll be changing my tranny oil regularly. So be ready for finding a lot more in need of fixing as you go into the tranny. Email me directly if you want a suggestion about getting bearings.
Kurt_JDB
03-25-2006 05:43:37
 Re: Gear damage in reply to 2cylinderlp, 03-24-2006 19:22:45
Your picture looks very similar to what I found in my B. Everything is also very loose.
Thanks to all who replied. I am leaving town for most of the week, and will not be able to get back to this until then.
JD man, I live in Raleigh, NC. I would be interested in your Diff gear.
Kurt
